well me and my buddy are working on his pro x 440 and the gas is definetly getting to the carb but it wont run, so we can pour gas in through the top of the cylinder and it will fire but die after like 10 secs. Any suggestions on what to do???
Tough to diagnose but if gas is getting to the carbs the fuel pump is working, the fact that the gas is not passing through the carbs says the carbs need to be pulled and cleaned properly. When you pull it over numerous times do the plugs get wet? If that were the case could be old gas...
