Anyone know where the fuel filter is located? Behind the airbox or is it in the tank? I can't find it anywhere. No problems, just want to stay on top of preventative maintenance.
Thanks!
Live To Ride
If im thinking of the right thing that your looking for its in the fuel tank on the end of the line that goes into the tank, thats where it was on my 2002 edge body
There's a weighted filter on the end of the intake hose inside the tank. Some sleds came with an additional filter between the tank and the fuel pump. You can also add one there as well. It's a lot easier to get to!
Thanks BC Dan. I tried to find the filter with a flash light, no luck. How are you supposed to change that filter?
Where should I put an extra filter? Like right in the middle of the line that runs between the tank and pump? Or should I favor it closer to one or the other?
