define intermittently. if you mean sometimes it works perfect and other times it just goes "click" it could be a loose terminal but very well could be a dirty starter. if it goes click every time you know key conections are good. i have cleaned many starter motors on sleds and boats and it works 99/ of the time. check terminals first (thats to easy) lol so its probobly starter.
I had the same problem and found a cracked ground wire lug, fixed it and all was good.
Your Bendix on the starter may have some water in it and ices up. That could prevent it from turning out and engaging the ring gear.
