1 - 18 of 18 Posts
I have a 2002 600 efi apv that my son rode then parked. A few days later it started but backfired and wont restart ( or stay running). I have another 600 efi so I have checked spark(good) switched fuel pumps , ecu and still nothing any ideas?? plugs look dry!? not wet so i put gas into jug and still just poping not starting
I just checked the reeds and they are fine I will check compression tomorrow but it almost tore my arm off with a backfire in the middle of a pull so my arm is to sore to keep pullin tonite so back at tomorrow even check the servo motor with a battery supply hooked up and thats good too!!!
good thing I have another one to ride but i wish this one at this time was elec start!!!
Have you checked the reeds? The back fire may have ruined them? But it would stil run!
You have spark, have you checked compression @WOT!
I just did and they are both @ 90 do you think it could be the timing sensor and if so how do I check it?? just fishing but i am a little lost with this one. I have also changed the fuel regulator, coil and still wont stay running
also is there a way to check stator with a volt ohm meter that you know of or do you need to bring it to the dealer?
Alex
Don't run around your problem!.... You NEED a Top End! 90 PSI is inadequate and will cause these problems.
How many miles are on it? Is it the original motor (never rebuilt)?
Alex
Take both plugs out, throttle fully opened, and pull until the gauge stops rising (likely 5-8 pulls). Engine will read higher when cold, so running pressure will be lower than what you get (unless you can test it when warm).
Many dealers will recommend rebuilds at 110 PSI or 5000 miles. Most engines will still run until 95-100 PSI... but need to be rebuilt.
My girlfriend had a 2002 ZL 600 EFI and i did a compression test and got about 116 psi. Sounds like a top end would be a good way to go and if you can do it yourself it is really not that much money and just my 2 cents i would use all OME parts
Discussion Starter · #13 ·
JUST DID THAT AND IT READS 120 in both
Discussion Starter · #14 ·
just did it and it turned out 120 psi in both so i dont know where to look
My tps sensor wires got frayed and shorted out. I got crazy backfires when I tried to start. Check all connections. I have a used stator for sale if you need one from a 02 600efi apv.
1 - 18 of 18 Posts
