I'm sure this is really NOOB, but how do I stiffen up my rear? It's got a lot of travel but feels like it doesn't have a lot of tension. I can push it down very easily. Also, there's an adjustment knob right in front of my handle bars that the previous owner told me adjust ride height or something... anybody know what that does?
On the rear swing arm there is a triangular shaped block that the end of the spring rests on. Use a spark plug socket/wrench to turn it so that the thicker segment is under the spring.
In this pic it is the black plastic piece that the spring rests on.
That Knob on the Limited edition pushes more oil down into the shock to tighten up the dampening! Most likely your springs are worn. See about a new stiffer set (Sno Pro is the stiffest)
