i have a 2001 srx I just recently purchased and the temp light keeps flashig. it flashes 3 times then a pause then 3 then a pause etc. it does it from cold start on and never quits. would appreciate any info thanx
problem with the temp sensor or the wiring to it. check the green plug that come up under the water rail on the right side and confirm connection. then check the wires to be sure they arent shorted. lastly, you can check the sensor.
