· Registered
Was working fine when I pulled in the garage, tqo days later took it out for a ride, starts fine idles fine, only lets you go 35 the bogs out, carbs taken off all cleaned still does the same thing, when you check the spark plugs, their loaded with gas, good spark on both sides, and when your riding behind it you spell gas???
· Administrator
If it has enrichment circuits in the carbs, I would look at that... or if it's got a plunger, maybe there's an issue there? I would also make sure the floats are set to the correct height and that they are not sinking. Also check the line from the fuel pump to the crankcase to see if it's got fuel in it. If it does, the fuel pump diaphragm may have ruptured
