I let it idle too long I believe it overheated and blew off a hose coming off the coolant bottle now I can't get the coolant to cycle through the rear exchanger what do I do please and thank you
You need to get the front of the sled up higher than the rear heat exchanger so the air can navigate its' way out of the cooling system. If you have a tilt trailer, that works great. If not, put the skis up on something like a milk crate and sit on the back of the sled to get the springs to sag. Idle the sled with the cap off to evacuate the air.
