I let it idle too long I believe it overheated and blew off a hose coming off the coolant bottle now I can't get the coolant to cycle through the rear exchanger what do I do please and thank you
Try picking up the front of the sled. You will have to get it up a couple of feet so the motor is way above the exchangers. You may have some air in the system if it blew the hose off. By picking up the front, the air bubble will work it's way out of the exchangers. This is the method when changing the coolant. If the sled has never had the coolant changed before, now is a good time to do it. It does wear out over time.
