Hi, I have a coolant leak from between the cover and head on my 700. I have never seen inside a sled engine before as this is my first one. I rode it yesterday for the first time and need to fix it asap for christmas sledding with buddies. Anybody got any advice? thanks
It wouldn't be bad to replace all the gaskets, but it is probably your head gasket... also, there would be a gasket (o-ring) on every head bolt, and gaskets around the plugs (if its like mine) I don't use it but my one friend just uses that gasket maker and fills in the week points... (never leaks for him but he's one lucky SOB)
I would check and make sure all your bolts are tight before you even mess with gaskets.
