Hi I have a 2000 mxz 700 and it keeps dropping a cylinder, when I clean the carbs it stays on 2 cylinders for 10 minutes and then drops back down to 1. I clean the carbs then switch them around so the one that drop the cylinder is on the right side, it only drops a cylinder with one carb if I switch the carbs around it’s drops a cylinder on the other side? Does anyone know why it’s doing this
Welcome
Most likely the carbs need to be cleaned.
Pay attention to the pilot circuit and remove the air screw as well as the Pilot jet (up the tube)
Spray all those passages
