This front wheel on my x-tra10 suspension keeps coming loose.
I've tried lock tight & all without much success. Seems as though the aluminum bracket that attaches to the rail & the rail itself have
become slightly deformed from being loose. Does anyone have a suggestion here? What will the result be if I just take that wheel off & have only 2 on that side?
If I understand your question correctly, It sounds like you need to add a bushing to the rail, ( to correct the OD spacing around the bolt)and even put a thin spacer behind the nut so that it tightens down better to the rail. That should solve the problem. The thin spacer might do the trick all on its own, because the thickness of the rail has been worn from the bolt wobbling around in there.
I hope that helps.
