I have a 2000 Yamaha Venture 600 (Triple).
Removed Carbs to clean for Idle issue.
Unfortunately also unconnected and removed coils.
Was wondering if anyone knows order the coils are daisey chained together?
Two wires come from harness on right side (as you are sitting on sled), then each coil is connected to the next. At least that is what I think.
Obviously order needs to be correct to fire correct cylinder at TDC.
Any help would greatly be appreciated.
right to left as your sitting on the sled we will call it coils 1-3 and following the male/female orientation of the bullet connectors and 2 wires per coil, the orange wire from the harness to coil 1, the black wire from the harness to coil 2. other wire from coil 2 to coil 3, remaining wire from coil 3 back to coil 1.
Thanks Yamadad4.
Will give that a shot. Starting to get lots of snow here in Mich.
Can't wait to get on trails.
thanks again.
