My 2000 800 RMK has developed an idling problem. At idle, sometimes it starts backfiring "mildly" and then dies. About the same time this started, the brake indicator light (in the gauges) started flickering on an off, when the brake is not on. The brake light does not flicker as bright as when the brake is actually applied. I think these are two separate problems that just coincidentally started about the same time, but I am stumped. Has anybody had similar problems with a Polaris, or any suggestions?
Klutes,
I have a 2000 sled and haven't had any problems yet but I have heard of a few people complaining about wire harnesses rubbing through and shorting out. It sounds like you have an electrical problem. I'm not sure if this may cause the backfire problems or not If you have wiring problems anything is possible. Good luck
