2004 F7 EFI Sno-Pro
ok this sled has the safety feature where if u let off the throttle quick the sled will shut off what do i have to do to make it not do that i think theres something i have to remove but i ain't to sure
Throttle safety
The sled has a throttle safety switch that will shut the sled down if it malfuntions. If you let off the throttle quickly it should not shut the sled down. The throttle safety or throttle seats may need replacement. Disconnect the switch and try running the sled, if its bad the sled will run fine.
