Snowmobile Freak!!!!!
Can someone please tell me what the default "factory settings" should be for setting the idle screws on each of the 3 carbs. The carbs only have an idle screw (screw with spring) and has no air screw that I see on the carbs. I read that you suppose to tighten each screw all the way in and turn 1 1/2 turns out to each carb and that will be factory setting at 1500 rpm. Is this correct or should the idle screws be set different?
Thank you in advance.
Discussion Starter #2
Ok I just found the little air screw and I didnt touch the screw at all. Now I just need to know how many turns the idle screw should be turned for proper idle.
