I was 5 miles from home last night and my headlights were flicking on and off, both low, high beam and tail lights. Guy behind me said the brake light was on steady. I started it this morning and the lights were on steady so I wiggled wires trying to find problem but found nothing. Seemed problem is only when riding. Anyone else ever have a lighting problem like this on a later 90's Arctic Cat?
my son had the same thing happen to him last weekon his 97 ZL 440. he just tapped the headlight a few times and it stayed on steady. When we got back to the shop I opened the hood to have a look and found nothing wrong. I would like to hear an explanation for this too
Make sure that your harness is still zip tied to the hood by the light and also should be on a zip tie anchor under the ecu. then check each gang plug for corrosion or at the very least they my have gotten moisture in them causing a temp short.
