Step father bought the sled a couple of days ago. Seller stated they didn't know what was wrong, they had needle and seat replaced.
Not trusting people I checked plug on mag side soaked but has strong spark. At this time I did full rebuilds on both carbs, drained all fuel from case ( there was alot ) and put fresh plugs into the sled. Started the sled and it is only running on pro cylinder. I found that I turning the fuel off gets the mag cylinder to fire, turn fuel on and it stops firing. Swap fuel lines same issue, swap carbs same issue, swap choke and throttle plungers, same issue. Tested compression 110 on mag side and 120 on pto side... I would not think this would cause the issue but I have now rebuilt the top end on the sled pistons rings, gaskets honed cylinders the whole nine... now testing the compression pre brake in both are at 125, now I expect aftet brake in this will stay close to the sames (at least balance out ) but I am being preemptive and looking for other ideas.
