· Registered
Hi everybody, first post here, and also my first snowmobile. Also I hope Yamadad is ok! I tried to research this before I posted, and his posts really helped me grasp the basics of these carbs. I recently started rebuilding the carb on my 97 VT600 (smart carb). Which was so smart, that they only built it I guess for a few years. I pulled the carbs and they were pretty dirty! The solenoid on the main(green sleeve/ upper) was clogged pretty good!
Wood Tool Hand tool Metal Gun accessory
Well parts are hard to source, and I had a question cross referencing o-rings for Fuel Cut Solenoids. Does any one know cross-referenced part numbers for these or do I need to buy a master o-ring kit, and match up that way? Thanks in advance for your time!
Gas Household hardware Auto part Metal Gun accessory
· Registered
I just checked, and you can still get the factory O Rings that are listed above. I found them at Rocky MT MC/ATV. They will have to order them. These will be metric, so finding them in your local area will not be easy unless you have a Yamaha dealer. Just go with the factory O Rings and save yourself the hassle.
