1997 Skidoo Skandic 377 continually stalls after the engine warms up. What would.cause this and how can I fix it? Any advice would be appreciated and Thank you
Welcome
Start with a complete carb and jets cleaning and passages
Check the float turns off at 'Level'
Then check the TSS and replace the spark plug coil with a known good one!
Check your spark plug wires. Unscrew the spark plug caps and trim back the wire about 1/8" and screw the cap back on. As the plug wire warms up, it could be losing connection.
No TSS on this sled. Other than that, check your crank seal, sure sign of leaking is that you'll have oil all over the back of the clutch. Again, cold it might be fine, but once it gets hot it leaks.
If you can do a video (or even just audio) that would be helpful.
