Hello, I’ve recently been rebuilding a 97 indy 500 and I damaged the flywheel dismantling it I was wondering if anyone knew if a flywheel off a 1985 indy 400 would will work they have different part numbers on them Just Wondering if this would work thanks !
Administrator
I would try to find one off of a 500. That engine was very popular back in the day. There should be tons of parts available. Check at a salvage yard such as www.alssnowmobile.com and get the right one. That way you don't have to worry!
Some 400 parts were the same as the 500s but not the flywheel. You need to find one from a Indy 500 '92 through 1998 with the Fuji Engine in it.
You didn't say which model you had but the EFI used a different flywheel. All other 97 models used the same fly wheel which was also used in the 440 L/C from 92-98, 440 XCR 92-93, Widetrack LX 91-99, Fiji 500s from 92-99.
The EFI flywheel was the same from 94-97
