I am having trouble with me Wildcat. U can go down the trails it runs just fine then all of sudden it starts acting like the gas is to lean on it. we replaced the fuel pump, fuel regulator, and the fuel sensor on it. If got any ideas holla at cha boy. later
hey did u ever figure out waht was wrong with it ?
having the same problem
sometimes on my cat if i hit the throttle just right the safety switch will activate and bog it down dont know if this may be issue but just an idea...
mike
Angry 1996 Wildcat EFI
I had a similar proble with my 93. I talked to my mechanic, and he told me that if you have low voltage in the system the brain goes into limp mode. If you have a battery get it checked or replace it. Also check that your regulator is functioning properly.
