My track is 133.5... is there an easy way to fit a 136 track instead? And... If I wanted to put a larger lug track on, what size can I go to? I found a 133.5 x 1.5" will that fit? How do you make it fit?
You would have to drop the mount bolts down likely. Don't know about the 136" Maybe move the mount bolts down and forword? if there is room without hitting the tips on the drivers?
Will have to take a look tonight. I am assuming there are not holes to move the mount bolts down, I have seen others modify there machines by making new holes. Is this wise?
