I have a formula III triple 600 and the right side carb must be bad. I think the engine is flooded. When i took the pipes off the right one was Full of gas. then when i put my finger to touch the reeds there is gas all in there. First question is if there is a drain on the engine to get rid of that gas in the crankcase? then what would my problem be? floats bad or what? Please help. i have nto been able to ride this t=yet this year. Thanks i also need to know where to put the two screws on the carbs? how many turns out? thanks
clean your carbs,make sure they open at the same time,check your floats,the air screws should be 1 1/2 out
