it comes out of the chaincase side. with the chaincase removed and the speedo cover removed, the shaft needs to slide to the clutch side and then it will come out of the chaincase side, angle it down and back a bit, and then pull it out of the clutch side.
dont forget to loosen the set screw on the clutch side bearing so it can slide on the driveshaft to gain clearance for the shaft to move toward the clutch side.
hope that made some sort of sense.
