Hey!
I have a 1995 Grand Touring 470, that for the most part runs really good, the only issue it has is that it seems in deep snow, it occasionally wants to bog out and the engine just seems to sputter. So basically low speed, deep snow, lower RPM, and it just dies. It is tough to keep going cause you just hit the throttle and it sounds horrible and doesn't go anywhere.
The compression is fine at ~130 in each cylinder. I've had both carbs apart, and same with a local guy that works on sleds, and the consensus on them is that they look good. This moves me on to electrical.
What should I do to try and pinpoint what the issue is? The kill switch does seem to have issues sometimes, could this be causing my problems? I've suspected the coil, but it doesn't seem to be a general issue once warmed up, but maybe the increased load on it from the deep snow is enough. If I had it bogging out on my, and then immediately after go to a hard packed trail, it runs fine.
Also, does anyone have some good jobber sites for a Canadian (Manitoba) to order parts for a sled of this age? Thanks for all your help!
