I have a guy in my area that has 1994 Arctic Cat Wildat 700 EFI with 2177 miles on it.My friend talked to him,and from what he said it starts,and runs,but after about 15 minutes it shuts off.Someone told him that all that needs to be done,is to have the computer reprogrammed. Can this be done?Is it worth the trouble?I have seen the machine,but haven't heard it run yet.From the looks,it's just like brand new!He only wants $450 for it.What do you think?Any help is greatly appreciated. Thank You very much!
Tyler
I should mention that the battery must be charging for it to run right and if not it will go into limp mode and not run above and idle. check to see if the fuse is blown and that the battery is bood and the regulator is working.
