1 - 9 of 9 Posts
i bought a 93 ext 550 was told it ran fine last year it just needed a recoil the motor turned over fine by hand and had good compression i got it home got a recoil put it on only to find out it don't have any spark I changed the coil still no spark any suggestions thoughts or advice i was told it is a really good dependable sled
i have the same sled (mine is carbed) it is dependable. Once running. Check out the video at the top of the page regarding kill switches and t.s.s., it might help you diagnose the problem.
If you have a tether, I'd bet that is the problem. I had hell with the tether on my EXt till I replaced it. Your stator is good. What jumping the wire showed is that it's either your key switch, tss, or tether if you have one.
Dang..he's got it fixed even before I chime in.
1 - 9 of 9 Posts
