I have a phazer that won't run with the air box on. I cleaned the carbs, adjusted the floats, cleaned the air box, floats have no holes, tried new spark plugs, checked the seals. I am stuck i can't figure out what the problem is...Any advice would be appreciated.
more information please.
first, dont run it too long without the airbox or you can damagae the engine
will it run without the airbox and then when you install the airbox it does nothing?
at this point is the hood up or down?
when you say it wont run does that mean it wont start, or it starts and doesnt want to go anywhere?
lets go from there.
first thing i would rule out would be an obstrution in the exhaust. pull the pipe, shake it, and listen for rattles or watch for crap falling out the exhaust outlet. (rodent nests)
air in, no air out=bog
