Guys pls help. Carbs are cleaned twice over coils have been swapped compression is 120 per side checked for bad crank seals. Still Boggs at 3000rpm at full throttle. But if I let it die down to idle and ease into it and go full throttle it revs up
An update on my findings!
The TORS was my problem. Had to
bypass this feature and it was all there. No more bog!
What you do is splice the 2 male ends of the TORS harness connections together and your in your way.
After sitting in the woods for 6 years, I got my ‘83 Excel III running today.
It still needs work to run good, but it’s a start. One cylinder was locked up, but I got it freed. I’m going to change the chaincase oil, fuel lines, filters and clean it up. I should have it ready for a test drive...
Have 1980 artic cat panther rebuilt fuel diaphragm pump last winter and had to fill fuel lines every time to get it going. this year filled up lines with fuel and it will run till that fuel is used up but will not pull anymore out of tank. Replaced all fuel lines and vacuum line. Put finger over...
Never done it before is it hard? Any tips? I ordered a cable from Parts Reloaded... the old one is still functioning, but is frayed badly with just a small strand holding it. My main concern is the rubber handle bar padding... how does that come off? Any suggestions are welcome!
Hi All!
I just picked up a 1978 John Deere Spitfire for $250. The seller claimed it runs, but cold start is rough. When I went to pick it up, we couldn't get it to start. The ceramic material in spark plug caps is broken and electric tape was wrapped around it so the cap would stay on the plug...
