I have taken the 5 bolts off, and I can pull the chaincase out a bit, I can rotate it, but it just doesn't seem to want to come off the lower drive shaft. Anyone have any suggestions? I really don't feel like droping the track etc to remove it !
the shaft is pressed through the bearing in the housing of the chain case .
if you have access to a dead blow hammer carefully drive the shaft out of the bearing
(the bearing should stay in the housing) as to not damage the splines on the end of the shaft.
