My clutch has bad bearings in it. I am hoping to just get a new (used) unit to swap on, but I am curious if the 377 clutch is the same. They look the same in most of the ads I see but I don't know how to verify what parts mine might cross with.
Any info would be great.
Ryan
Secondary Spring...
Spring pre-load might be different. Probably the same spring, you'll just need to move the spring to a tighter hole.
If I recall, the 467 is a liquid cooled vs the 377 being a fan. Quit a bit of difference in HP. Probably the difference of around 35 HP vs 55 HP.
