The wires that go to the switch on the carb are the ones to put together to eliminate that switch being bad. The dead man switch I was talking about would be the tether switch, sometimes they get weak and dodn't hold the button in far enough to maintain contact . The throttle switch I think is in the housing on the handle bars, you could trace the wires from that switch to were they plug into the harness and pulg together and bypass that switch.
Maybe the kill button on the handlebars is going bad, and you could trace the wires from it back to the harness and bypass it.I am thinking it has to be a switch or bad wire connection giving you fits.
