My Uncle gave me his old 1981 Citation 4500 that was sitting in his barn. I put all new gas lines, plugs, filter and cleaned the carb. The problem I have is, it will start up with the primer but then stall right away. It will run if I continue to use the primer or give it a lot of gas, i mean A LOT! When you give it full throttle it will drive but it is barely moving. Every so often if you give it a pull on the primer it will get full throttle but it lasts for a second only. I cleaned the carb a few times now (taken it totally apart). There are no cracks in the intake, nothing in the exhaust. I put in fresh gas too. I am just stumped. I looked online and everything I found said it was the carb, but like I said, I cleaned it out twice now, jets are all good, nothing gunked in it. Any ideas??? I don't want to bring it to a dealer as it is not worth it. This is for my kids to tool around the yard with.
