my sleds a 74 chappy ssx 440. i have quite a few questions...
what is the best way to adjust my carbs..?? everytime i ride i have to get new plugs. im running ngk-br9es. it seems like my left cylinder loads up and fouls my plug out. my carbs are synched and clean. at first if i hit full throttle from take off it bogs down then when i release a bit it will pop pop then take off. i have to eeze the throttle then floor it if i want it to open up like it should. there is many aftermarket parts on this engine so idk i think its a spark problem sumhow. cuz if im not gentle with the throttle it seems like it will bog down. i have to listen and feel if its running rite then i can open it up but only sumtimes it will most of the time if i just try to floor it it will bog down then i have to back off the throttle till it runs rite then i can hit it all the way.. COULD IT BE my coil? any help is very appreciated. thanks alot everyone
