Alright guys, need your help finding my TPS.
I've never had a problem with these before. And, it's very tight under the heat shield.
Doesn't help I have intercooler piping in the way.
Code 07, stands for open circuit for my TPS. However, trying to get under that heat shield and IC piping without removing it is my goal, but I can't find the TPS. Did a little research online and haven't been able to find a good picture of the location.
Any help appreciated.
You might as well start removing everything! It will be on the end of the throtle shaft. But Hopefully it is just a melted wire coming from it!
Well, I had an idea of where it was. But I didn't want to pull everything off.
Ended up....... pulling everything off.
Thanks for the help
