Hi there first time on here I have a 2007 skidoo rev 800 x 159 and it bogs out at high rpm last year in the powder it pretty much loses all its power at the start of the season last year I had lights my tack was working g break lights were also working now none of them turn on now whe. I put it in reverse it no longer has its beeper and loses all power and bogs out bad was wondering if it could be the voltage regulator or the stator or something else ?
Administrator
You can test the output with a volt meter. If the sled doesn't have a battery, it's probably A/C voltage... if it has a battery, the regulator also has a rectifier in it to convert A/C to D/C.
I would also make sure the regulator has a good ground...
