do 04 saber cats have a stock hook up for a heated shield? i looked for one and couldn't find it i don't want to cut in if there is one already. it is efi but not electric start. and if not what wire should i cut into? thanx
If you pull the black fiber cover down from under the hood you can gain access to the gauge and headlight wiring harness with in those wires you will find an unused plug that should have 2 brown wires going into one side and 2 yellow wires going into the other!! the yellow wires are your hot wires and the brown are your ground
