the springs are rubbing the shocks really bad on my f7, anyone else have this prob and know of a fix. if anyone knows offhand is the wider more compressed part of the spring towards the top or the bottom of the shock. mine is toward the bottom, i was thinking of switching it if it would help?:confused:
four gear pinned
There should be a plastic piece that goes around the shox body that will protect from rubbing. if the spring is wound to tight that also might cause a problem
