1 - 1 of 1 Posts
I HAVE A BAD CARB ADAPTOR/ REED CAGE ON THE CLUTCH SIDE CYD. THE RUBBER CRACKED OPEN CAUSING AN AIR LEAK. HAS ANY ONE ELSE HAD TIS PROBLEM? JUST WONDERING IF IT IS A OEM PROBLEM OR A RARE OCCURANCE. ANY SUGGESTIONS AS IF AFTERMARKET IS THE WAY TO GO,USED,OR NEW OEM. THANKS,TIM
1 - 1 of 1 Posts
