I have an '03 F7 with 450 miles that is bogging down at half throttle. Changed the plugs and still have issues. Is this a common problem for the F7?
I'm also glad to know that mine isn't the only one sucking a quart of oil every 100 miles. My dealer told me that's the way they are, based on Arctic Cat's recommendation. Is this a load of bull?
Thanks for any suggestions.
i have a 2003 f7 and mine uses a quart of oil every 230 miles. sounds like you could have some efi issues. maybe your sled is putting a rich mix in your mid range. mine never bogs down either
tell your dealer to turn the pump down, if he won;t call another dealer until you find one that will. as for the bog, my 04 has it on the holeshot so far i have had it rejettd and took out a shim, going to switch to a smaller belt and see if that eliminates it, it is a lot better then it was when i first got it.
