what is belt deflection? i herd about shimming and the distance between the primary belt and the side of the clutch what should i check and where should i make an adjustment what would i want and what wouldnt i want? whats stock and whats modifiedthankss
also if i have a yellow epi primary spring and 1062 weights i want to put 1060 in would it be better? or worse
and i have a 21 tooth gear should i go back to the 23tooth?
01 600 edge x
3"riser
snow stuff can
blue progressive secondary spring helix in thrid hole
yellow epi primary 1062 weights
21 tooth gear from 23
380jets
45 piolet
down one on needle jet clip
01 600 edge x
3"riser
snow stuff can
380jets
45 piolet
