Is this a problem with my dropping resistor?
The LH injector plug shows "0" volts, key on.
The RH injector plug shows "12" volts, key on.
Sled runs, but only on the one cylinder.
Help!!!????
Yes the circuit splits at the dropping resistor, so it would be the logical place to start to
look for a break. Corrosion is common near the dropping resistor connector.
Thanks for your input. My sled is out in my new shop that I'm building and I'm heading out there to work today, so I'll look for that resistor again. I couldn't find it last time i was looking. If that's the problem, that would be an easy fix. The sled ran great last year, so I can't imagine there is too much wrong since then. Just right now it's running on one cyllinder, and crappy at that!!!
