05 xcsp 700 flooding - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 10 (permalink) Old 10-09-2019, 01:45 PM Thread Starter
Ive been working on this sled for a while now and cant figure out what is wrong with it. the motor was flooding out last season to the point were it would lock up from all the fuel in the motor and fuel was pouring out the exhaust header. i replaced the floats and needle and seats, cleaned the carbs out very well and it still lets fuel right through into the motor. am i missing something?
cgroenier is offline
post #2 of 10 (permalink) Old 10-09-2019, 06:01 PM
Quoted: 62 Post(s)
Welcome
Just replacing the needle and seat does not mean it wont flood!
A simple adjustment of the float to 'Level' would have likely been all that was need to begin with.
To adjust the float 'Level' simply add a piece of hose to the inlet, and blow into it (with your mouth)
Then raise the float till it wont pass air.
At that point the float should be 'Level' with the carb body, adjust the little tab to get there
KCCats2 is offline
post #3 of 10 (permalink) Old 10-09-2019, 07:44 PM
Quoted: 196 Post(s)
I would also check the fuel pump diaphragm, it may have a hole and is letting fuel into the crankcase via the impulse line...
BC_Dan is offline
post #4 of 10 (permalink) Old 10-09-2019, 07:53 PM
Quoted: 19 Post(s)
I was just gonna post that Dan,lol. I've had a couple pumps go bad and flood out my carbs then fill up the crankcase with fuel.
Coolhand is offline
post #5 of 10 (permalink) Old 10-09-2019, 10:40 PM
Quoted: 196 Post(s)
Gonna have to type faster next time
BC_Dan is offline
post #6 of 10 (permalink) Old 10-10-2019, 03:23 PM
Quoted: 19 Post(s)
Nah gonna have to not be extremely sore and barely able to move from putting a new computer desk together, new 32" LG 2k resolution w/ G-Sync and redoing the entire bedroom setup,lol.
Too old for this garbage anymore!
Coolhand is offline
post #7 of 10 (permalink) Old 10-14-2019, 10:30 AM Thread Starter
KCCats2:
Thanks for the reply, i have adjusted the tabs on different carbs in the past but these are one unit and plastic so there is no tab to adjust.
Thanks,
Cgroenier
post #8 of 10 (permalink) Old 10-14-2019, 10:34 AM Thread Starter
BCDan,
I took it off and blew in the impulse line and no air came out the upper lines so i figured it was good. i will take it apart and check it out for sure tho. the carbs are full and the boot going from the carb to the motor is wet so fuel is for sure getting through the carbs.
Thanks
post #9 of 10 (permalink) Old 10-14-2019, 07:11 PM
Quoted: 196 Post(s)
Sure sounds like an inlet needle/seat issue, then. I'd follow KC's advice and check the float adjustment.
BC_Dan is offline
post #10 of 10 (permalink) Old 10-15-2019, 06:54 AM
Quoted: 62 Post(s)
Yes you can adjust them it's just harder.
Make sure all is clean and test again
If you have to adjust the plastic just heat it with heat gun and hold the tab where you want it then run cold water over it
KCCats2 is offline
