Replacement Skis for old Sled - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 4 (permalink) Old 03-21-2019, 11:15 AM Thread Starter
I have a 1987 Ski-Doo Escapade/Safari 503.
I want to replace the beat up metal skis.
Does anyone know of a replacement kit?
Would this work which I found on Amazon: Ski-Doo 860200524 Pilot 5.7 Ski Upgrade Kit
72fb is offline
post #2 of 4 (permalink) Old 04-02-2019, 02:31 PM
TheBearAk's Avatar
Quoted: 84 Post(s)
I've not found a kit, but I usually just fabricate my own. Adapting skis to the post is one of the easiest mods you can do on a sled. I have a set of aftermarket skis that were meant for a 99 Cat on a Skidoo Touring. Just took a few spacers and made plates (bolt holes are larger on the skis).
That said, the Pilot skis might be a bit over-keel for that 87. (like that play on words?) The keel on the bottom of the pilot ski is about 1" deep. That 87 may end up putting to much pressure on the skis and might not be able to adjust out of it. I'd bet the height difference including the keel is close to 2" from the bolt hole to the bottom of the ski.
That is a lot of adjustment for a suspension.
1995 Skidoo Summit 583 LQ
1985 Skidoo Tundra 250F
1999 Arctic Cat Jag 340F
Currently working on:
TheBearAk is offline
post #3 of 4 (permalink) Old 04-03-2019, 06:29 AM
Quoted: 58 Post(s)
I have Cat skis on my Yamahas too.
The Polaris uses a 3/8" bolt instead of the Cat 7/16" if that helps?
Most of the time I see Plastic pull off skis with carbide for about $100 a set or less even at Swap Meets!
KCCats2 is offline
post #4 of 4 (permalink) Old 04-03-2019, 10:30 AM Thread Starter
Thank You for your feedback.
72fb is offline
