burning coolant - Snowmobile Forum: Your #1 Snowmobile Forum
post #1 of 5 (permalink) Old 03-03-2019, 10:10 PM Thread Starter
burning coolant
resurrecting a 2002 600xc.
idles good, runs good, unless I really get on it for a few seconds and it starts to bog and coolant steam comes out of the pipe through all the leaks and kills the motor. the owner replaced the head gaskets without success and gave up. ended up parking it for a few years. I wonder if he got the heads torqued wrong. or a crack. strange how its only an issue under heavy load. preasure build-up pushing coolant past the gaskets?
Hengst is offline
post #2 of 5 (permalink) Old 03-03-2019, 11:50 PM
Quoted: 191 Post(s)
It could be a cylinder crack or could be a warped head. Were the base gaskets changed too?
I would get a straight edge on the head and check it. If it's out a little, it can be sanded flat on a sheet of fine grit sandpaper placed on a very flat surface. Sand in a figure 8 pattern and keep even pressure on the head. Check often so you don't do too much in one area and ruin it.
If it's out a lot, you can find a good used one for pretty cheap.
BC_Dan is offline
post #3 of 5 (permalink) Old 03-04-2019, 07:46 AM
Quoted: 57 Post(s)
Yep warped head
KCCats2 is offline
post #4 of 5 (permalink) Old 03-04-2019, 10:14 PM Thread Starter
got all gaskets on order. tear it down tomorrow to get a look at the head
Hengst is offline
post #5 of 5 (permalink) Old 03-05-2019, 06:57 AM
Quoted: 57 Post(s)
Jugs too!
KCCats2 is offline
