The protector's are for your rear heat exchanger[if you put one on your viper] they mount from the top of the rear tunnel to just above your snowflap. If you have a studded track and would happen to bottom out you'll most likely hit your exchanger with the stud's, and in some cases actually cut open your exchanger sending coolant all over. I don't have any picture's on hand but if you go to
www.TotallYamaha.com and ask around in the forum's i'm sure somebody would have some picture's. They had some posted last season showing what kind of damage the stud's would do to the heat exchanger. Check it out, I hope this helps!
