87 phazer - Snowmobile Forum: Your #1 Snowmobile Forum
Old 01-05-2013, 07:25 PM   #1 (permalink)
87 phazer
i took my phazer carbs off and took bowls off and i.uave these black plugs where are they suppose to go in the carb and also noticed.that the guy who had it before me.nade his own out of electrical tape so i have a total of 3 blaxk plugs and dont know where they go and need to fibd out where i can buy one of those plugs
Sent from my SAMSUNG-SGH-I997 using Snowmobile.com App
eag1e1004 is offline   Reply With Quote
Old 01-05-2013, 08:00 PM   #2 (permalink)
part # 8VO-14118-00-00. you need 4. expect to pay around $5 each. any yamaha dealer or online parts provider will have them.
i have posted the correct location several times, but for a refresher, with the carbs upside down and the airbox side facing your belly, the left and center pilot tubes get the caps. the right side remains open.
just so you dont get confused, the larger round parts of the carbs are the airbox side, the smaller sides go to the intake boots.
Old 01-05-2013, 08:40 PM   #3 (permalink)
thanx bud ur a great help
Old 01-06-2013, 01:19 PM   #4 (permalink)
now its leaking fuel out of the hole on the right side of carb on top out of a hole on.the carb is that a breathet
Old 01-06-2013, 01:37 PM   #5 (permalink)
that would be an overflow and usually a good indication of a sticking float or a needle not sealing to the seat.
Old 01-06-2013, 06:00 PM   #6 (permalink)
how do i fix that problem with it it jus happened the other day
Old 01-07-2013, 07:01 PM   #7 (permalink)
clean the needle or buy a new needle and seat.
Old 01-07-2013, 08:36 PM   #8 (permalink)
where is needle locacted
Old 01-07-2013, 09:13 PM   #9 (permalink)
the needle is the thing that is attached to the tang on your float. the tang is the little silver tab located on the float where the pin that secures the float to the carb body is. the portion of the carb that the needle sits in is referred to as the seat.
if the needle doesnt seal properly to the seat, or the floats are bad or stuck, fuel will keep flowing beyond the holding capacity of the bowl and overflow out the vent tubes.
Old 01-11-2013, 05:00 PM   #10 (permalink)
fixed.that issue all i had to do was go out on to lake.and open it up a little bit and now runs like a champ
Old 01-11-2013, 05:01 PM   #11 (permalink)
now nother question my buddy has a enticer its a 81 82 and he needs track clips we were out rideing and.he lost all track.clips from one whole side of track any ideas where to.get some for cheap
