fuel pump - Snowmobile Forum: Your #1 Snowmobile Forum
Old 01-03-2013, 09:38 PM   #1 (permalink)
El Tigre Kid's Avatar
fuel pump
well i figured out why my sled keeps flooding out, the diaphram in the fuel pump is bad and is allowing gas to go directly into the crankcase. My question is is a SRV Fuel pump just a normal Single mikuni pump? it says mikuni on it and its only a single carb so i am imagining it is. I have a brand new rectangular single mikuni fuel pump i bought for our AC Jag i didnt use it though. Can i use this? the one on the srv is round but should be the same right?
~``Tyler Brode``~
-1979 Arctic Cat El Tigre 6000
The Sleds
-1979 arctic cat jag 3000
-1979 arctic cat el tigre 6000
-1984 yamaha srv 540
Past sleds
1979 el tigre cross country cat
1985 el tigre 6000
1977 el tigre 4000
1978 jag 2000
El Tigre Kid is offline   Reply With Quote
Old 01-04-2013, 05:49 AM   #2 (permalink)
You can try it, but it is likely that the round one has a larger capacity [more cfm].
If you find the engine starving for fuel at higher speeds, then simply rebuild the original pump.
Old 01-04-2013, 09:16 AM   #3 (permalink)
Ok I will I would think it will work
~``Tyler Brode``~
The Sleds
Past sleds
1985 el tigre 6000
1977 el tigre 4000
1978 jag 2000
Old 01-04-2013, 09:48 AM   #4 (permalink)
ride till your broke
Renagade's Avatar
i agree, the round pump is larger capacity.
current sleds
04 rev800ho gade
95 formulaIII 600
77 olympic 340e-mint!!
Old 01-04-2013, 10:11 AM   #5 (permalink)
I have a new round pump for double carb. Can I just run both out puts into a T connector and run one line to the carb. ??
~``Tyler Brode``~
The Sleds
Past sleds
1985 el tigre 6000
1977 el tigre 4000
1978 jag 2000
Old 01-04-2013, 10:17 AM   #6 (permalink)
Yes or just plug off one.
Old 01-04-2013, 10:25 AM   #7 (permalink)
Ok thank you
~``Tyler Brode``~
The Sleds
Past sleds
1985 el tigre 6000
1977 el tigre 4000
1978 jag 2000
