studs on track - Snowmobile Forum: Your #1 Snowmobile Forum
Old 01-02-2013, 07:06 PM   #1 (permalink)
studs on track
Hi! Im wondering how long of studs i can put on my track i have a 94 yamaha v-max 600 le with a 1.25 lugs on it. Im trying to get it ready for next weekend where we have a speed run out on the lakes. Any help will be appreciated.
VmaxFan94 is offline   Reply With Quote
Old 01-02-2013, 09:06 PM   #2 (permalink)
smokingcrater's Avatar
how big of drivers on it? If its stock, I'd say that ANY studs are going to be pushing your luck with clearance.
3) 2004 Yamaha Warrior
4) 2006 Yamaha Nytro
smokingcrater is online now   Reply With Quote
Old 01-02-2013, 09:24 PM   #3 (permalink)
if you mean by the drive axle i think its stock.
Old 01-02-2013, 09:42 PM   #4 (permalink)
yep, well, the cogs on the axle in particular. If you look up under there, there is VERY little clearance between the tip of your current lugs and the front heat exchanger. Studs are obviously going to be hanging further out, and will contact your heat exchanger occasionally. (i've got a .875 track that has studs that are maybe 1" out, and my front heat exchanger and tunnel shows plenty of marks from contact. I'd be worried about anything longer than that, its only a matter of time before one goes through the cooler.)
Old 01-03-2013, 10:50 AM   #5 (permalink)
Well the studs isn't going to be permanent just in for the day and out the next just trying to get traction when doing the speed runs on the lake.
Old 01-03-2013, 10:53 AM   #6 (permalink)
Go with the Woodys low profile screw in studs.
Old 01-03-2013, 03:59 PM   #7 (permalink)
I was doing some reading on the screw in studs and it sounds like they tear out at a high rate if speed.
Old 01-03-2013, 04:10 PM   #8 (permalink)
No, they have been in use for motorcycle ice racing for decades.
Finally have been adapted for sleds.
I use the embedded ones as they have the lowest profile [less that 3/8"].
You can use more without adding significant weight to the track and they cost less too.
I just run them into the lugs with my rechargable drill.
In two years of use, I've only lost two heads off and there was never a worry about exchanger damage.
Old 01-03-2013, 04:15 PM   #9 (permalink)
Where is a good place to get those kind of studs and how many go into each lug
Old 01-03-2013, 04:21 PM   #10 (permalink)
Available directly from Woodys or any of the retailers online.
I used 4 across, every other lug on a 121".
Old 01-03-2013, 11:21 PM   #11 (permalink)
How long of those screw in studs I should go with
Old 01-04-2013, 05:53 AM   #12 (permalink)
The longer the better, just get the length that matches the lug height minus 1/4".
In mine, the lugs are 1", so I used the 3/4" long.
